I have a 2002 with V8 4.7 ltr. What I am experiencing is that high speeds the rear end wobbles and I replace the shocks so far and that helped a little but it's still wobbly any suggestions.
Rotate your tires and see if it moves to the front, if it does, it's probably a bad tire, or out of balance. If it doesn't move, check for a bent rear drive shaft, bad ujoint or bent axle.
Is it lifted? What size tires?
I will check as soon as I get home, thanks
I now have a rear main seal leak in my 1989 Jeep Cherokee Limited. Based on what I see on Utube, this can be a tricky job. Any input is appreciated I.e. How much to have a mechanic fix it, etc. thank you
