1 - 3 of 3 Posts
Here’s one for you guys, I have a 98 check sport that has an issue with the left turn signal and the right head light.
when I turn my signal on he right head light flashes also, just opposite time as the turn. One turns on while the other turns off and vis Vera.
And I don’t have high beams unless I disconnect my right head light.
Ideas are welcome.
Whenever you get crazy stuff like that, it is generally a poor or no ground so the current feeds into whatever it can. Find all your grounds and clean them and it will probably be fixed
4.3 XJ said it check the grounds first. Next did you change your lights to LEDs, cheap LEDs can cause problems. I had weird issues related to my LED swap. While trouble shooting them found my light harness was in such bad shape it was easier to totally rewire the headlights and running lights/turn signals.
1 - 3 of 3 Posts
