1 - 3 of 3 Posts
I have a 1995 Cherokee Sport. The headlights do not work. The running lights ( the small lights under the headlights) work fine as do the side marker lights, so I’m thinking it’s not the switch.
The vehicle was used mostly in Mexico and in the summer, so corrosion isn’t a primary suspect right now.
I checked the 40A fuse and it’s OK. The brights work fine - except they won’t latch when the headlight switch is out. Since the marker ligthts and running lights work fine, I’m thinking there’s a relay somewhere that I can’t find that would turn on the lights.
So, where is the regular light relay?
You probably need a new multifunction switch in the column
· Super Moderator
If you have daytime running lights, the module is between the PDC and blower motor.
1 - 3 of 3 Posts
