This may be a dumb question but I have the RE 1660 tracbar and was wanting to know if a TRE would be better than the heim or just leave it alone. It is a DD so mostly street use. Thanks in advance for the help.
The RE1660 trackbar doesn't use a heim joint, it has a Superflex joint. It also requires the RE1665 trackbar mount.
If you've got the RE trackbar with a heim joint, that's the RE1600. IMHO it's much better off with a tierod end instead of the heim joint, but at ~$40+ for a quality tierod end it's also not worth it IMHO to spend the extra money to "upgrade" it. So yeah, I think it's better off with a tierod end, but I agree with the other guys that you'll probably be just fine with it as-is, just be sure to tighten the hell out of the frame-side mounting bolt.
