I have a 1994 Cherokee 4.L High Output.
I can not get the Part Time 4 wheel drive light to go off after I have engaged the lever back in 2 wheel drive.How do I resolve his as I can not drive around with part time 4x4 on?
Thanks in advance.
Yeah, first make sure if it's still in 4WD or not. Then check/adjust the linkage to get it back to how it should be in each range.
Mine will stay on for a few seconds also. I will usually drive it back and forth a lil bit until is disengages the light. You should be able to tell if it is still in 4wd once you move the lever to 2 also. I have the 242 so I use the 4wd on regular roads all the time.
When this light is on is the truck still in 4wd? If it is then I would be willing to bet that your linkage is messed up. But first try rolling backwards a bit and disengaging it in that respect.
I rolled back a couple times and Bobs your uncle & Fannys your Aunt!! :thumbsup:
Have only had the Jeep for a week now and very impressed...rugged and feels muuuuuuuuuuuuch stronger then my Land Rover Freelander.
Thanx for all the advise guys..:pop:
