done:thumbsup:hold on, let me look through the fsm real quick here, pm me your email address please
I use Castro GTXi sent you an email. IIRC the 4.0 according the the book uses the weight of oil you are using. One thing you can do is run better oil, like Castrol or something, and a better filter.
If this is something that came on all the sudden with your oil pressure, you need to really double check the level of your oil. If you are adding half a quart and asking about adding more, you really need to look that dipstick over good. If the oil is so black you cant read the dipstick through it, then change the oil with some good oil, put on a good filter, and put in the amount of oil your owners manual says to add.
Well if your sockets wont fit then you need a wrenchdo I need a wrench, its a pretty tight spot.. my socket wont fit there..
did I got it right? the thing is, Im not sure what should I be pulling up the PS pump? im sorry if I sound dumb, I just dont want to mess this upok so i loose the bolt, pull up to loosen the belt, then push down to tighten and then tighten the bold did I get it right?
