1 - 1 of 1 Posts
my 90 cherokee hesitates when you start from a stop, and the idle drops and then surges when you take your foot off the gas. my tps reads correct voltage when tested ,the idle motor is clean and carbon free, the crank sensor and the map sensor have been changed. I had a problem with high idle but resseting the computer fixed that, what have I missed? this is my first jeep so I couild sure use your help. thank you swells, so. Utah
1 - 1 of 1 Posts
