I'll preface this by saying that I was bored after work, had my XJ, and was just wanting to see if I could ACTUALLY do it with materials I had laying around at the shop.
I chose to use 1"x2" angle iron as opposed to flat stock for stability in both directions.
I started by examining my axle and making sure it was true, and thankfully not already slightly bent.
I then took a piece of cardboard and made a template of my mini-truss.
I transferred the template over to my stock.
Then I cut along the lines with my cut off wheel.
Back to the bench grinder I went to clean up any rough edges and burrs.
Test fit truss in place.
Cleaned off top of axle tube for a good welding surface.
Burned in name off offroad club. <---Not Required...
Tack welded truss in place and checked for proper alignment.
I then burned it on in...
A shot of rust preventative paint and good to go.
This is my first attempt, so feedback is welcomed.
Take care and be safe wheeling out there...and as always...tread lightly.
Not bad, but I'm suspect of the gap on the pumpkin end of the brace. I think that overall, it would have to make the housing stronger though. I'm a stickler on weld appearance too, but I'm sure the welds are plenty strong!! Thanks for the post!!
