Brakeline Extender Bracket
Keep you informed? Okay.
You all have heard about my rear brakeline extender bracket.
And seen this pic of the prototype on Lil Red:
Well after a long time of designing and CNC milling, I have arrived at a production prototype. This design repositions the mounting point of the stock XJ brakeline UP 2" and FORWARD 2" and ANGLES it upward 8.5*, regaining brakeline slack lost from 3-3.5" lifts.
Why not just get longer brakelines??? Anyone ever TRIED to remove the fittings from 15 year old steel lines? What happens. TWIST/KINK/BREAK. Then you do this....:brickwall:
Pictured is an unfinished unit. They will get my favorite finish...black epoxy.
I designed this bracket to re-use the axle-mounting bolt with the built-in breather tube (as shown in Lil Red's pic). There will be hardware supplied to affix the brakeline to the top-end.
Axle-end has the correct radius that mates to axle tube, as does the top for the brakeline.
Stock XJ steel lines along the axle have enough length to allow repositioning.
Constructed of SOLID steel. No aluminum to crack.
