Jeep started making a constant squeak, but it almost sounds more like a whistle from a teapot kettle. Curious if anyone has been through this and could point me in a direction to track it down.
Here are symptoms: It occurs only when rolling, and only after driving a block or so when things get warmed up. I can hear it the second I start slowly rolling (like just letting off the brakes in drive and letting it coast). It stops when Jeep stops.
It is constant and doesn’t “pulse” like brakes usually would. I can kill the engine and coast in neutral and still hear it.
I first noticed it shortly after switching out my Lock Right with a Powertrax No-Slip in the D30. It wasn’t immediately after, but that was the last mod I did prior the noise. I also developed a bad axle seal leak on driver side, probably damaged the seal during the job.
I had someone listen from outside and he said it sounds to be coming from the front, but not specifically either side. Pads have a lot left, although they have some cracking in the material. Squeak is unaffected by braking.
Some background on the Jeep
98 4.0 Auto, 160k
231 with SYE and new shaft
Front shaft is stock
4.5” with 33’s
Powertrax No-Slip front and rear
Any thoughts?
98 4.0 Auto, 160k
4.5” with 33’s
Any thoughts?
