21 - 40 of 41 Posts
DUDE!!! You have seriously got to see this video.
Discussion Starter · #23 ·
That was hard to watch, Gluck, but so is everything else that moron posts on YT.
It was tough, but my goal was to promote the durability of the Toyota, which it does. I think he is an ass.
Discussion Starter · #26 ·
Been a minute....heres the front axle so far. Im not done, but its getting close.
Looks very nice. I have front end parts if you are interested. Axles, hubs etc
Reactions: XJSuperman
Discussion Starter · #29 ·
I wonder how bad shipping would hurt from cali to iowa? I could probably use a set of spare axle shafts and hubs...send me a pm on what you're thinking.
Discussion Starter · #30 ·
Finished axle in primer. Armor completed.
Very nice. Did you measure those front shafts yet?
Discussion Starter · #32 ·
Discussion Starter · #34 ·
Haven't updated for a moment. Last weekend was a productive one. I managed to remove the transmission and transfercase Thursday night by myself, then took Friday off work and loaded up everything and headed to a friend's. We removed the t-case and then disassembled it for the doubler kit. My friend gave me a trans and t-case to use so no my truck is getting a 5speed swap. I removed a 4spd, but originally the truck had a 5spd, so I'm happy. The 5spd also has a lower 1st gear and is a bit stronger.
So the doubler kit is almost finished and everything is home again waiting to go back in the truck. I messed up the threads on the output shaft, so I bought a 20mm die to fix it, I just haven't gotten to it yet.
A Doubler - cool
Discussion Starter · #37 ·
And I got way behind in updating this....the build is still going. And it snowballed a bit...
Discussion Starter · #38 · (Edited)
Pic dumps coming right up.
Axle finished and installed with 5" leaves up front.
Rear springs purchased and in the process of installation. I had to move all the mounts and extend the frame.
Frame was patched in the rotten spots Toyotas get.
New used fully welded rear center section was acquired from a friend after discovering mine was rusted after the rear end was full of water.
As of right now the truck is sitting on its own weight up front, but the rear is only partially in place for mockup. Im hoping to weld it all in this weekend.
After that the next step is building the caliper mounts and getting the rear disc setup configured.
Tire Wheel Vehicle Car Motor vehicle
Hood Motor vehicle Automotive tire Wood Bumper
Tire Wheel Vehicle Car Automotive tire
Automotive tire Asphalt Motor vehicle Bumper Gas
Discussion Starter · #40 ·
More pics...
Tire Wheel Vehicle Motor vehicle Automotive tire
Automotive tire Motor vehicle Bumper Wood Gas
Automotive tire Motor vehicle Automotive design Wood Vehicle
Automotive design Motor vehicle Art Automotive tire City
21 - 40 of 41 Posts
