Like I said I just picked up a 99 XJ.
4x4
4.0
Auto
156k miles
I only paid 800. Body is pretty good. A couple dents. Glass is good. It has a hack job exhaust where they cut the muffler out and put the wrong size exhaust pipe so not at both ends it is rinckled and leaks. This will be question 1. The heat only blows out of the defroster, I need to check the vacuum lines. The other problem I have is in the trans. The shifting is off. Sometimes it clicks through the gears perfectly fine. Other times it will shift early and then no drop in to over drive. This will be question 2.
My plans with this vehicle are to replicate a specific jeep I found and I attached it. I am planning on going with a 4.5 lift. I will not need long arm as it will not be my trail rig. I am currently looking for another to build my trail rig.
So gents.
Question 1-
Can I run the exhaust with no muffler and not get a caution from the downstream O2 sensor?
Question 2-
Should I waste the time having a diagnostic done or just replace the trans?
Thank you for any input,
Michael
4x4
4.0
Auto
156k miles
So gents.
Question 1-
Question 2-
Michael
