1 - 12 of 12 Posts
First, I want to apologize up front about my lack of knowledge. Does anyone know where I can find an ignition actuator pin for a 1983 Jeep Cherokee with 5.8L? Or a work around? The vehicle (recently purchased) currently has a toggle and push button start and I'd like to switch back to a key. Any help would be greatly appreciated.
I had to look at your other thread first and realized we are talking about an FSJ, not a later Cherokee. Im not making any promises, but I was thinking those had GM ignition switches in them? Should be super simple to get one at a parts store. I don't know much about the FSJs though. Sorry.
Did I post in the wrong forum? I have been looking in parts stores and so far have been out of luck. I will check out the GM ignition switches. Thanks.
No you're technically in a fine place. Most of us have XJs, ZJs, and other newer Grand Cherokee models. We don't get many FSJs on here, but we have nothing against them. It just means the help may be a bit slower lol.
Here is a link to www.rockauto.com for the actual ignition key cylinder, is that what you need?
Not quite. There is an actuator rod/pin that goes between the cylinder and ignition switch.But thanks for looking for it. :)
I sent them and email seeing if that part will work. But that is what I am looking for. Thank you for all the help and support.
Also Ben you may want to look at the FSJNetwork forum, very active FSJ community.
Discussion Starter #11
Update: The 1983 Jeep Cherokee had a GM steering column so parts from that should work. I have not acquired one yet but will soon.
Glad to hear it!
1 - 12 of 12 Posts
