Hey all,
I'm seeing this is a fairly common problem, I was working on replacing a brake line in my 1998 cherokee sport last weekend and when I went to take her for a test ride I noticed I lost the entire instrument cluster... I know the speedo, tack, odometer, oil pressure and temp were all working not sure about the voltage meter... So I'm seeing that this is a common problem and was possibly considering doing away with the entire stock instrument panel.. I guess where I'm trying to go with this is I am considering getting rid of the stock gauges and going all aftermarket.
I'm wondering if anyone else out there did something similar and if so could you make any recommendations to equipment used or pointers...I'm partial to aftermarket gauges basically because of accuracy and partially cause they look good....lol.....thanks for the help and advise, much appreciated...
AJ
AJ
