I'm having a problem when I turn my signal stock to the left position it turns on my rear hazards. The right signal works fine and the hazards work fine. It used to be intermittent but now it's become almost every time I turn my left signal on it turns on the back hazards, the front signals are working normally it's just my passenger rear wants to do more work than it has to. Any thoughts about what I should do?
Year and model and do you have the trailer wiring package?
Generally the problem is with that trailer wiring
Reactions: Gluckmysock
There is a little box that converts a 5 wire system to a 4 wire plug. They can malfunction
Discussion Starter · #7 ·
So should I try unplugging it and seeing if that works? The wires dont look chewed, is it the pigtail going into the trailer plug cavity?
Yes
