1 - 3 of 3 Posts
I just purchased a 93 cherokee with chrysler rear end, I was wondering if this has limited slip in it already or should I install a rear locker? If it does have l/s, how do I tell?
Depends what you are looking for. There's a pretty big difference between limited slip and a locker...
Anyway, if you want to know if you're equipped with limited slip, jack up the axle in question, put the transmission in neutral, and spin one of the tires.
If the other tire spins the same direction: Limited Slip
If the other tire spins the same direction: Open Diff.
Later.
If the other tire spins the opposite direction: Open Diff.
Later.
fixed it for you!
1 - 3 of 3 Posts
