is there any way somebody could write up a list of tools i will need to put on a 3" lift kit
i dont have a air compressor so no air tools
i do have a bunch of tools but i would like to be ready for any thing.
basicaly im looking to compare what i got to what i need and fill in the blanks
thanks in advance for the help :cheers:
Jack stands
Metric and sae sockets
spring compressors (optional)
BF-Hammer and punch in case you snap the upper shock bolts
vice grips
torque wrench
jack stands
jack
pb blaster
that's pretty much what i use when installing lifts.
With an add-a-leaf to do...
You need a couple of C-clamps to reassemble the pack
Are you doing anything about the brake lines??
If so you need line wrenches.
How are you planning on removing the existing pack clamps and centering pin?
I grind them both off. But you could use a chisel and hammer to break them.
If you are not going to use spring compressors on your coils, you need to be able to jack the front end up high enough to let the axle droop down enough to remove the coils.
