1 - 20 of 35 Posts
Discussion Starter · #7 ·
yeah.....water is fun....at the momment...after is like.....NOT
Dude i think we should swap screen names for the time being.
Flood the interior? Looks like it since your girl has her feet on the seat.
Discussion Starter · #10 ·
yeah there was water inside...its ok i have no carpet...lol....
the wagoneer is a beast...36s swampers....MANUAL!!..
Discussion Starter · #12 ·
no roll up....i have to re doit....and prime it better this time....the heat makes bubbles under it....so im going to grind it off then...prime the hech out of it...then do it...im also going to put the gas tank inside....fold the rear panels...and...mm....put the battery in the back...
You going to go with a fuel cell?
Discussion Starter · #14 ·
yeah...im still looking i saw an awesome write up in pirate to put the stock gas tank inside and make a box around it out of aluminum so the gases dont come in...and just leave a little space for the fuel pump so i can take it out any time..and skit plate the bottom....
and i dont run any danger with the batterys there if i do that..if not im doing a fuel cell...
Well be sure to do a writeup:cheers:
Discussion Starter · #16 ·
for sure....so are we going to exo-iner you cherokee or what????.....:p:p:p
give me sometime ...i may have something in a far future for you...:thumbsup:
Discussion Starter · #20 ·
if not there close enough....and i have some goals..so....stick around...
1 - 20 of 35 Posts
