1 - 2 of 2 Posts
2020 v6 trailhawk
the contents of my little jar of lubricant seem to have congealed a bit over 6 years. Is there anything magic about this stuff? It is now somewhat stiff, but I can push a screwdriver into it easily, and it leaves a greasy slime on the blade. I can order the lubricant jar for another company's tire repair kit. I've searched the ARB site and haven't found a replacement.
Two points:
-If it leaves a slimy film on stuff, then keep it and use it as intended. Push the tools into it when you need to use it, and be done with it. Many kits don't even have a lube in them.
-ARB kits appear to come with lube still, but you can buy lube at any automotive store or online. Amazon lists several options. Chances are the lube in your kit was made by someone else for ARB anyways.
1 - 2 of 2 Posts
