Congratulations to S8NNG8 For winning May 2019 Modified Cherokee of the Month
'95 XJ Sport 2dr
4.0 HO/ax-15/231
Black trim delete:
Chrome roof rack
Chrome drip rail trim
Chrome cargo runners
3rd crossbeam (light bar)
Chrome door handles
Chrome grill/headlight bezels
Diamond plate armor:
Rocker panels (Warrior Products)
Body corners
Taillights
B-pillars
Hood vents
Door handles
Towbar
Hitch
Hatch
Airdam
Front bumper endcaps
Custom tire rack (roof)
Suspension:
Rustys 3"front/3.5" rear (full spring lift)
Rustys adj uca's with flex joints
Rustys adj lca's with flex joints
Extended wheel base
JKS 1" dogleg shackles
RC adj trackbar
RE swaybar links/ offset fix
Crown HD steering assembly
YJ brakelines f&r
97+ ps e-brake cables
Axles/tires:
Regear 3.07 to 3.55
'96 hpd30
'98 C8.25 (29 spl)
Poxycoat restoration/custom paint
ABS delete
Rims: Ultra Drifter 15x8 (-19os) x5
Tires: BFG AT KO2 32x11.50 x5
Exterior mods:
Raptor lined undercarriage
Rustys rear trail bumper
Detours folding tire carrier (in the bumper receiver so I can still use the hitch)
3/4" d-rings with isolators
Rear 2" reciever
Front towbar with removable tongue
5/8" d-rings
Lund visor
Black vinyl 2-tone (will serve as gasket for future armor)
Wagoneer taillights (silver trim removed)
Cree 2x2 led pods (rear bumper)x2
Cree 2x3 led pods (lightbar) x4
KC 6" Slimlights (front bumper)
Under the hood:
Spectre cowl intake
Stock airbox delete
Optima red top (primary)
Optima yellow top (secondary)
Ballistic Fab battery boxes
Painless Wiring digital power manager
Headlight harness upgrade
Autopal e-code housings
160A alternator
Browndog brackets and motor mounts
Diamond plate relay mount
Diamond plate ecm remount
Interior mods:
Carway pet barrier (stopped body flex)
Gear shift shortened 2"/ skull knob
Dash reupholstered/ black carpet
Diamond plate switch panel
Cobra 75-wxst cb
Firestik KW4 antenna/ swivel mount, spring
Alpine CDA9886 CD/DM head unit
Alpine S 5 1/4 x4
Rockford Fosgate bd1000 mono amps x2
Kicker L7 dvc 10's x2
Fusion power cap 1.5far
Inverted bandpass sub enclosure
0awg power cable
Stinger breaker switch
Stinger pro series rca's
Stinger pro series Y cables x2
Onboard gear:
Fire extinguisher (front console mount)
Hi-lift jack/ Poxycoat restoration
Smittybilt X2O 10k winch
RC TJ winch plate
This is still one of the most badass yet tastefully modded Cherokees I have ever seen. Thanks for sharing your work and dedication with us man!
Thank you bud! I appreciate the acknowledgment. This September will mark 10yrs that I've had her. But it's still evolving. Years worth of change have yet to come. ?
congratulations. That's a sweet ride you have dude.
