1 - 16 of 16 Posts
We are now accepting entries into Modified Cherokee Of The Month.
Provide us with some pictures of your Jeep and as much information as you can. We will add the poll after we have received (5) entries.
Jeep Of The Month Rules for the Modified Category:
* To qualify for modified class Jeeps must have 2.5" or more lift and 31" or Bigger tires.
* Mods will announce and open up a new thread for submissions each month
* Must be an active member of CT to participate
* Must include a minimum of 2 photos and a maximum of 5 photos and info as listed below
* Entries will be accepted until the 25th. Merry Christmas
* Entries may be closed early if there are too many entries for the current month
* There will be a maximum of five (5) entries to be voted on per month
* Mods will open up a poll so that members may vote for their favorite Jeep
* Winners to be announced on the 1st of the following month
* Any Jeep not selected as a winner is free to enter again in following months.
* In case of a tie the moderators will decide the winner.
* Rules may be changed, modified, added or removed as deemed necessary by the moderators of this forum
* Winners must wait 1 year from date of winning before entering again
*The winners of each month will be put into a COTY (the year) poll- At mods discretion
Mods will choose up to five (5) Jeeps of those nominated below to be voted on by board members
To nominate a Jeep, please supply the following information:
* Year:
* Model:
* Engine:
* Mods/Custom Stuff:
* Other Info:
* Photos:
Good Luck!
Can I get in this month?
You won in April 2018. May 2019 is 13 months later, so Technically Yes, Butttttt
You are co winner of Cherokee of the Year Which means you won that in January 2019.
Butttttt
The the rules don't say anything about waiting a year after winning COTY,
Butttttt,
Since I am moderator, I can change the rules! :p:p:p
Buttttt,
I
am
not.
So Yes you can enter!!!! Woot Woot!!
'95 XJ Sport 2dr
4.0 HO/ax-15/231
Black trim delete:
Chrome roof rack
Chrome drip rail trim
Chrome cargo runners
3rd crossbeam (light bar)
Chrome door handles
Chrome grill/headlight bezels
Diamond plate armor:
Rocker panels (Warrior Products)
Body corners
Taillights
B-pillars
Hood vents
Door handles
Towbar
Hitch
Hatch
Airdam
Front bumper endcaps
Custom tire rack (roof)
Suspension:
Rustys 3"front/3.5" rear (full spring lift)
Rustys adj uca's with flex joints
Rustys adj lca's with flex joints
Extended wheel base
JKS 1" dogleg shackles
RC adj trackbar
RE swaybar links/ offset fix
Crown HD steering assembly
YJ brakelines f&r
97+ ps e-brake cables
Axles/tires:
Regear 3.07 to 3.55
'96 hpd30
'98 C8.25 (29 spl)
Poxycoat restoration/custom paint
ABS delete
Rims: Ultra Drifter 15x8 (-19os) x5
Tires: BFG AT KO2 32x11.50 x5
Exterior mods:
Raptor lined undercarriage
Rustys rear trail bumper
Detours folding tire carrier (in the bumper receiver so I can still use the hitch)
3/4" d-rings with isolators
Rear 2" reciever
Front towbar with removable tongue
5/8" d-rings
Lund visor
Black vinyl 2-tone (will serve as gasket for future armor)
Wagoneer taillights (silver trim removed)
Cree 2x2 led pods (rear bumper)x2
Cree 2x3 led pods (lightbar) x4
KC 6" Slimlights (front bumper)
Under the hood:
Spectre cowl intake
Stock airbox delete
Optima red top (primary)
Optima yellow top (secondary)
Ballistic Fab battery boxes
Painless Wiring digital power manager
Headlight harness upgrade
Autopal e-code housings
160A alternator
Browndog brackets and motor mounts
Diamond plate relay mount
Diamond plate ecm remount
Interior mods:
Carway pet barrier (stopped body flex)
Gear shift shortened 2"/ skull knob
Dash reupholstered/ black carpet
Diamond plate switch panel
Cobra 75-wxst cb
Firestik KW4 antenna/ swivel mount, spring
Alpine CDA9886 CD/DM head unit
Alpine S 5 1/4 x4
Rockford Fosgate bd1000 mono amps x2
Kicker L7 dvc 10's x2
Fusion power cap 1.5far
Inverted bandpass sub enclosure
0awg power cable
Stinger breaker switch
Stinger pro series rca's
Stinger pro series Y cables x2
Onboard gear:
Fire extinguisher (front console mount)
Hi-lift jack/ Poxycoat restoration
Smittybilt X2O 10k winch
RC TJ winch plate
woot woot go dude
1 - 16 of 16 Posts
