Let me preface this by saying that as of right now (11/08), I've got no trail time at all with this setup, and very little street time, so the design as it stands may be changed if it looks like it'll need to be beefed up more.
This was also my first real welding project, so many of the welds look like poop but they should be strong enough. Also, many of the welds are multiple passes which is why some may look built up or extra boogery.
The complete build photo album is here: http://jeepin.net/fotos/installs/tractionbar
I got a lot of my ideas for the crossmember mount from Dirk @ DPG and Marty @ RLF from tractionbars they'd built for stretched TJs that had been converted to rear leaf springs. Due to torque jacking by the motor, the passenger side is really the side you want your traction bar to be on, but due to clearance issues with the exhaust on that side I opted to put my traction bar on the driver's side. I don't anticipate any issues from going this route.
Building the crossmember mount:
To combat binding at the crossmember mount, I decided on a dual flex joint design using large size Rubicon Express SuperFlex joints. One joint would be welded to my crossmember, the other joint would be on the end of the tractionbar, with a simple shackle connecting them. My DPG RockAttack belly skid is doubling as the crossmember mount for the traction bar.
1/4" plate to reinforce the rear edge of the belly pan.
Axle mounts:
I purchased these from DIY4x.com and was able to order them to my specs as far as bolt hole and axle tube size. They're 3/8" thick.
Axle mounts:
