I had the Rugged Ridge peices, and one tweaked on me a little on a rather difficult extraction, so make of that what you will. HTH!!
The C4x4 hooks were fantastic, I put them through the test several times and the brackets and hooks never bent or anything. Definatley worth the investment.
XJJeepThing's suggestion is also a good one. The front hitch will increase the rigidity of the front end by linking the framerails together. This will also be good for recoveries because the load will be evenly distributed between both framerails instead of just one when you use a tow hook.
