1 - 1 of 1 Posts
If you're looking to install a Brother USB printer, there are a few things you'll need to do first. Firstly, you'll need to make sure that your computer has a USB port. If it doesn't, you'll need to purchase a USB adapter. Once you have a USB port, you can proceed with the installation.
Next, you'll need to go to the Brother website and download the necessary drivers for your printer model. Once the drivers are downloaded, open the file and follow the on-screen instructions to install them.
After the drivers are installed, plug in your Brother USB printer to an available USB port on your computer. Windows will automatically detect the printer and install any additional drivers that may be needed.
Once everything is installed, you should be able to print from your Brother USB printer without any issues. If you're having trouble, check out Brother's support site for more detailed solutions.
1 - 1 of 1 Posts
