1 - 2 of 2 Posts
1998 xj classic when I put it in drive it hardly moves I have to manually shift it to drive took it to a tranny shop they said the tcm is bad and it’s in fail safe mode replaced the tcm and the same thing is happening any suggestions
Once you shift into first and the jeep is moving try putting into drive and see if it acts normal. Also try driving it kinda like a manual, shift through the gears. If it seems ok the most likely a shift solenoid in your tranny.
1 - 2 of 2 Posts
