ORO has just released these slick little LED rock lights. Each unit has:
* 18 Ultra bright White LEDs
* Embedded Magnet for easy installation
* Compact 1 3/4" diameter, 3/4" thick design
* Impact resistant solid polyurethane construction
* Fully sealed, corrosion and waterproof
* Draws 100 milli-amps each at 12 volts
* Weighs just over 1 ounce each
The full 6-pc kit shown above is $129, or you can get just a pair of LiteSPOTZ for $39. You can mount them using the supplied self-tapping screws or just stick 'em up using the embedded magnet! Now that's pretty slick.
The 6-pc kit is only available with the white LiteSPOTZ right now, but as individual pairs you can get them in white, amber, or red.
So far I've spent $180 for the 6 red LED rock crawling lights from roundeyes.com. They look cool, but these look a lot brighter and certainly are a lot cheaper.
If you guy just a pair does it come with the switch and all the needed wiring?
They come with a switch correct?
DOH, sorry, guess I should've included more specifics, haha. The full 6-pc kit includes wiring and a switch:
6-pc Kit Includes:
- 6 LiteSPOTZ
- Wiring Harnesses
- Wire Ties
- Switch
- Connectors
The 2-pc kit just has the lights (which have a length of wiring on them) by themselves, no switch.
