Names Richard. My ol lady & i have a 92 xj with the 4.0.Just had to change the head cause it was cracked. Got it put back together & running, but have no power. Need to know how to adjust the valves please.
Hello, and welcome. your engine has hydraulic lifters, valves can't be adjusted. Is the transmission shifting properly?
When I give it gas there is no power it boggs down. It will pull move itself at idle but when I give it gas it struggles.
Welcome Richard. Throttle position sensor hooked up? Sounds like it is disconnected or not working
When you rev it in neutral, does it hesitate and stumble before revving? And are you getting a check engine light?
