1 - 11 of 11 Posts
Hey guys!! Newbie to this site. Glad to meet you all. My XJ is a 1991 Sport. I have the 4.0 HO, AW-4, NP231, HP D30, D44, 4.56 gears and Aussie Lockers front and rear, Rusty's/Daystar 6" lift, Pro-Comp 32" mud tires, ORF bumper, XRC8000 winch, JCR Off-road rock sliders.
I do have a question to start off with. My 91 has the old vacuum disco front D30. I have read that getting a set of axles from a 92 or newer D30 would get me:
1.) No more axle disco to have to mess with?
2.) Thicker/stronger axle shafts?
3.) Larger 760 axle U-joints?
I was also wondering, would these newer axles bolt right into my D30 housing or are other modifications required.
I will post a picture of my rig as soon as I get home from work.
Welcome from Ohio...really you don't need a whole new axle housing to eliminate the disco...just get a one piece shaft from a 97+ xj, or a pre '97 xj with abs for the bigger u-joints. Remove the two piece shaft(s), the disconnect, and use a block off plate. Welcome again...
Thanks for the info. Grey. I just installed a front locker and everything spins all the time anyway, now. So, I figured I'd ditch the 2 piece wimpy right axle and disco to have fewer pieces that can break.
There's the pic.
welcome to CT from PR
edit: 2k post wooooh!!!
Welcome to CT from COS!!:cheers:
1 - 11 of 11 Posts
