1 - 2 of 2 Posts
My lo-beams haven't been working. Every other light works. Including hi-beams. The other day they randomly started working and never again after that. I changed all associated fuses that I'm aware of. I changed the column switch as well to no avail. I was thinking about changing the switch but after taking it out and inspecting it I don't see any damage on it or its associated connections. Wires also seem good as far as is visible. Both bulbs are also good. A multimeter would help. Has anyone else had experience with this?
should ba a couple relays by the radiator. check the wiring. 1 is for high beam and one is for low.
1 - 2 of 2 Posts
