Awsome! Thanks!I find that the electrical tape stiffens and gets hard after the elements get to it. If you look at the pictures I have of the temp senders in the post above(when I had just finished it from just under two years ago), those taped up connections have stiffened and unraveled to the point where one of the connections lost it's plastic coating and is now full of dirt and trans oil. I anticipate having to repair that connection eventually.
The cloth/tar-ish tape creates a water tight seal, and once the trans heats up a few times that tape is gonna be slightly flexible yet solid during everyday use. Also, once the dirt and dust gets on the outer shell, I think it'll be even more impervious to the elements.
Now, the last issue with the plug's wires melting most likely came from the internal temps of the transmission. I have the large cooler and the temp gauges for the trans oil installed since that event, and do not expect to have to ever pull it again to repair; mostly because I can monitor the internal temps at three different spots in the cooling circuit.
I wanted to have a water tight, element proof covering so as to not have any kind of chemical or oil on the wires that eventually could lead to degradation of the plastic sheathing of the wires. Resulting in having to do this repair again.
Ultimately, time will tell if this method will fail at some point, but I do not expect it to.
I'm Just curious as to some of the wired melted more of the insulation than the others?? Do you think it was because they were slightly farther away?? Sorry, carry on with the funeral!
