P/N engine block jeep cherokee 1994, 4.0L
3356 Views 4 Replies 4 Participants Last post by  trabots
Dear Sir,
What is the first letter for P/N engine block jeep cherokee 1994. 4.0L? is it start with M2K.. or MZK then follow by number? kindly advice please?
Regards,
'Dedi
The part number is not important unless you are buying a short block. Is that what you want to do? Dedi no one is going to be able to give you that info without knowing your vin.
Try this website.https://www.trademotion.com/memberservices/index.cfm?action=login&siteid=214358
I Ma new, I cannot find the "New Thread" button. This post relates to cast enegine numbers. I cannot find my 2000 4.0 Cherokee Sports serial number to show the licensing people. Where is trhis found please?
The engine cast # is found on the side of the block but not really visible without pulling the engine. The serial # is found on the lower left side of the dash (windshield) to the left of the steering wheel.
Thanks folks, it seems these engine serial numbers are found everywhere. I finally found it on my 2000 Cherokee Sport, Australian spec. It is located to the left of the distributor on a machined flat just underneath the cylinder head. Thanks for your responses.
