1 - 10 of 10 Posts
Hey everyone Im new on here. I have just ordered a lockright locker for my 2000 cherokee on the ebay store it said xj 93-and up with abs carrier I dont have abs and most of these say dana 35 I think by the way some pics look Ive seen online this maybe a chrysler 8.25 I know my front is a dana 30. Why and there is a chrysler simble on my rear end ??
You either have a d35 or a c8.25 in your 00. A c8.25 has flat corners on the bottom of the pumpkin.
Also the Axle tubes on the 8.25 are larger ( I think 2.25" ) where the D35 has smaller axle tubes (I belive its like 1.75")
Thanks, Like I said I wasn't sure of actual size just knew they were larger
if you have abs, its a 35. if not, 8.25. 8.25 is flat on the bottom too.
2000 Cherokee has a 8.25 rear. Now this might help but a Lock-Right for a Dana 35 can also be used in the Dana 30 front axle..
Serious? This is something i never knew. I had the 30/35 combo in my tj and never knew they were both the same. I ran lockrights in both.
1 - 10 of 10 Posts
