I see a case spreader. How much load is on the carrier bearings? I could pry mine out and tap them in with a big hammer? Also, are your bearing caps in the factory location? The patterns look pretty good.
I have between 30 to 35 in/lbs on the carrier bearings. When rotating the pinion with everything installed right now in at 35 to 36 in/lbs, the pinion itself was at about 28.I see a case spreader. How much load is on the carrier bearings? I could pry mine out and tap them in with a big hammer? Also, are your bearing caps in the factory location? The patterns look pretty good.
Checking runout on back side of ring gear, I also removed the ring gear, install carrier back in axle and torqued everything down and check the face, minimal runout. Must be I didnt stone it well enough, and after checking out some videos, im going to get more aggressive with it.Man dude. That's strange. Where are you checking runout, the back side of the rg?
Pinion preload seems a little high too.
