You probably have a bad ground for the signals and the power is going through the system backwards through any place it can find. Check the ground for your lights, and reground if necessary
Check the ground in the back. Behind the spare, under the plastic trim. Also Check your trailer plug,
So fellas I turn my blinker left and it turns on my right blinker in the rear only at the same time any thoughts?
Alrighty thanks for the time. I’ll try these first.
good luck
