1 - 7 of 7 Posts
Hi I have a 1989 Cherokee Laredo and the bleeder screws in the rear are stuck. Dumping a truck load of WD 40 or PB Blaster is not the answer. I want to bust em loose before having to purchase new wheel cylinders. Does anyone have any ideas or techniques to get them loose? I didn't round them off yet and I want to keep it that way. If anyone has any suggestions, let me know. I would appreciate it.:D
Put a little heat on them... Take it easy to not over heat the cylinders and melt the seals...
Also I have used a hand impact driver to get them out and just replace them.
i always use a small pipe wrench on my stuck bleeders and then repkaced em. i dont risk use a regular closed or open wrench cuz if they are really stuck then they will strip.
worst case scenario would be they are rust welded to the line and twist the line as they turn. been there, done that.
Web Wheeler
If all else fails, vice grips work great along with a ton of pb blaster and heat :)
All of the above, and depending on when they were opened last, all at the same time...
1 - 7 of 7 Posts
