I have had the worst luck with this...
Anyhow, trying to install a set of KYB Gas-A-Just rear shocks on my stock 1996 XJ, and working with the driver's side first. One of the bolts snapped, and I finally got that out of the way. Mounted the shock to the body and figured I could cut the retainer and quickly slip it onto the axle mount.
It didn't go that way at all. I can't get enough leverage on it from under the vehicle to compress it enough to try again. I've tried using a floor jack to push it back up, but since its force isn't straight up and down, it eventually wants to push to the side. I don't have anything to brace the jack to keep it from moving.
I know I'm not the only person to have had this issue. What do I need to do?
Thank you,
-William
Thank you,
-William
