Long story short, all equipment in my relay center doesn't work. This includes horn, turn signal, hazard flasher, power door lock and unlock, radio, and not that I've tested it, but I'm sure the rear defroster doesn't work either.
I've began testing for power after getting a wiring diagram for each relay in there and I'm not having any luck as to what the issue is. Powers where it should be, ground seems to be good from the relay block to body. Relays do click when I hit switches for each item, door locks, horn and turn signal, except with the turn signal it clicks once and locks up. Everything was literally just working about a month ago, now this.
It started with turn signals, they started going out, the relay would click several times, then they would lock up to the on position until I completed a turn. Then last week my horn just gradually quit. Then my radio no longer does anything, and literally, power door locks quit working last weekend.
I tried pulling fuses for the signals first since I've swamped the jeep awhile ago and never really clean the fuse block out afterward, then I just went through and cleaned all contacts I could since they were all dirty and have gone through some mud many times without cleaning. At that point is when I gradually lost everything on the relay panel. Every other electronic works in the jeep, windows, lights, etc.
What am I missing?
What am I missing?
