Ive been looking for like a month on a easy way to retard my timing:brickwall:. i found this ""If you have a Jeep with a standard transmission you can remove your crank position sensor (located on the bellhousing of the transmission) and take a small round file and elongate the holes to make it adjustable. You will want to go about 1.4" on either side of the stock holes in the sensor. This will give you about a 2-4 degree adjustment in timing."" But why would it only work on a STANDARD transmission?? I know its in the same place on a auto, well actually every vehicle. Do you guys think this would actually work? :dunno:
