1 - 12 of 12 Posts
Has anyone ever had the problem of the top shackle bolt not coming out? I used a lot of penetrating oil and the bolt was coming along just fine. It came out about 1/4 inch, then it just stopped coming out but it still turns. I almost think that the nut that is inserted into the frame has broken loose. Any ideas?
The bolt turns like it is coming out, but it doesn't. There is only one side of the bolt that I can put a wrench on and it spins freely.
the threaded insert that is welded to the inside of the frame has boken loose....you will have to cut a hole directly underneath it and tack it back into place...or hopefully get the sawzall in there to cut it.good luck!
I got it fixed. I removed the bumper and cut a hole in the very end of the frame. I had to cut the bolt in 3 pieces to completely remove it and the new bolt and nut went right in with no problems. The bolt that was tack welded inside had broken loose. I was able to cut a 3 sided flap and bend it up to access the bolt. Then I just bent it back into place when I was done.
Well im glad you got it fixed, now get some pictures up of the lift:cheers:
Its not much of a lift. The springs are sagging so bad, the two inch shackles and spacers just brought it back to stock height. I am piecing a lift together as I can afford it. I will get pics up of that when it is done. Hopefully in the next month or two.
had this happen to me today!!! used a small grinder wheel and cut a small slit under the area where the nut is, an air chisel came in handy to finish it off. had to bend it open enough to get a wrench in, wrench didnt help, i broke a craftsman, a snap on, and a cheap Taiwan wrench, so used a cuttin torch and cut the nut off through the half in slit. too much fun.:thumbdown: bought a new bolt, bought a new nut, fought with it for a half hour and finally got it in. then banged the metal back and welded it closed. not a fun job!!!!!!!! but i guarantee the final product will by far make up for it.
hope this helps!!
1 - 12 of 12 Posts
