My NSS is still bad, and today i had to start my XJ with a "trick" that i learned from the previous owner of my Cherokee.
The PO modified the Starter Relay in the PDC behind the battery, by removing the plastic case around it. I had to turn the Key on in the run position, pop the Hood, remove the Relay Box Cover, and push the contacts together with my finger.
I made it to work on time!
I just wanted to share this with you fine people!
Had to do it again!
Maybe i'll get my NSS cleaned when i do my 4WD Conversion...?
:blink:
Another way to do it is to just take the NSS wire to ground somewhere. It will start every time. But it will also do it in every gear.
