Hey Guys I’m new here and I also just got a 2000 Cherokee limited and I have been doing some maintenance on it. I got new front and rear sway bar bushings they are Polyurethane. So my question is what is the best lubricant for the bushings.
I'd go with good old fashioned grease. Or fluid film. That should keep you from having to do it often.
Honestly my bushings are pretty old and I dont think I've ever lubed them. No issues.
I just did the same up front, and threw some all purpose grease in there.
I hate clunky sway bar noise when the body bushings get worn.
That that rear swaybar and recycle it. You can use the axle side mounts as Bar Pin Eliminators later if you decide to lift.
