1 - 7 of 7 Posts
Well I finally installed my 3" lift. I ordered a transfer case drop before the install as a "just in case measure". Low and behold I had vibs at around 35. not bad, just enough to make me paranoid. so I went back and went to install the drop and couldn't figure out how to get the stud out. the instructions said to use either a stud extractor or vise grips. But does the stud come out or go in? What if it's seized?
Any info on how to do this would be greatly appreciated.
Thanks
Gnome
awsome. thanks a lot guys.
Make it easy on yourself. I just used the studs and put nuts on them when I had my TC drop on. I think they are M10 studs.
they aren't long enough.
Sorry, I reread the first post.:eek: I though you were going with a 1" drop crossmember. I used the studs with my 1" drop crossmember. My bad.:D
As stated before, you can lock two nuts together, and turn the studs out that way. You may need to put some heat to them, a propane, or MAP gas torch. I'll bet they are locktited in the nutsert.
1 - 7 of 7 Posts
