Will a 23 spline np231 from a 92 XJ be a direct bolt on to my 96 cherokee? What spline did the 96 AW4 use?
They're both 23 spline, so you'll be good to go. AW4s were 21 spline from 87 to mid 89ish, then they went 23 and remained that way.
The only thing that I think might be a problem is if the slip yoke is different on them. Later models had a retarded boot system with grease in it, earlier ones were just lubed with ATF from the tcase. I don't know when it changed.
