1 - 7 of 7 Posts
will a np231 from a 89 yj with a 4 banger "ax5" tranny...fit a 95 jeep cherokee 4.0 with a "ax15"?...
AX5 is a 21 spline output, and ax15 is 23 spline. You will need a new input shaft.
edit: ha, beat me to it.
ok...can you explain me a little be more about that....
thanks
The output shaft of the ax5 is slightly smaller than that of the ax15, so if you try to put the tcase from the ax5 onto the ax15, the input of the tcase would be too small.
Like stated before, you can convert it though.
scratch that!!.
i found one of an 96 xj...aw4...will that hook to the ax15?...
or do i have to change something??
1 - 7 of 7 Posts
