The Yeti Project
52347 Views 643 Replies 22 Participants Last post by  DaingMaing
So, after having done some things lately, it finally occurred to me that this thread should have been posted long ago.
I haven't decided if I will go back and re-post most of the mods that I did with her, here; or just link to them in brief succession. I suppose I just do the linking all quick like and save y'all some time.
This is what she looked like shortly after a 2.5" BB puck lift and WAAG Guards installed in the late summer 2007.
I think I have lost all photos of her from the weekend when I bought her in October 2006 down in Phoenix, AZ. I took in a MNF Bears Cardinals Game at the newer stadium (which was a comeback for the ages), and the very next morning I bought my Jeep. One hell of a weekend for sure, because they were who we thought they were and I didn't let her off the hook.
641 - 644 of 644 Posts
So thinking everything was mint, I pressed in/on all of the remaining bearings.
Well, I forgot that the gear oil will add preload. As for how much, I wasn't sure. I started out with .003 off of both sides of the carrier. Thank goodness for this carrier bearing removal tool. It is worth every penny.
Gas Cylinder Auto part Metal Wood
After a couple of in and outs with the carrier and the pressed on final bearings. We have the final setup numbers and patterns:
Pattern Setup Run #8: Final run
Inner Pinion Shims: .076"
Outer Pinion Shims: .069"
Pinion Preload @ 215 ft/lbs: 21 in/lbs rotation
NRGSB Shims: .051"
RGSB Shims: .037"
Backlash: .005"-.006"
Drive Pattern:
Tire Automotive tire Tread Automotive design Font
Coast Pattern:
Hood Automotive lighting Automotive tire Window Motor vehicle
14th time was the charm... 7% of the time, works everytime! 🤦‍♂️🤦‍♂️🤦‍♂️
Run 'M' :
Inner Pinion Shim = .074"
Outer PInion Shim = .067"
Pinion Preload = 28 in lbs
NRGS Bearing Shim = .046"
RGS Bearing Shim = .039"
Backlash = .0045-.008
NRGSB Shims: .051"
RGSB Shims: .037"
Interesting how close they are between the two sets. I did notice the difference in material/finish of the ring gear. It was different.
Having the previous numbers makes a great starting point. You have done a great job, Sir!
I had to replace my front carrier because the dana 30 has a carrier break. I was using a spartan auto locker. what type of locker are you using?
FWIW, on my gear install post, I linked to the Rustys Gear special. And they still have it available!! Sweet. Sorry. LOL I got a little excited. I went to see if they list the bearing brand but they don't. I'm 90% sure they are Timken.
When I broke mine in, I had it in 4wd full time. ran for about 20 minutes then let it set for at least an hour. The housings got pretty hot on the 1st few trips, made me nervous. but according to Motive Gear, that is normal. the heat buildup is necessary to temper the gears and finish the hardening process. I've had mine in for 5 years, wheeled with 35's through mud and rocks. Regearing is not hard, just tedious, nerve wracking and PRECISION work.
You've done all the right steps and put in the time. You're patterns look good, your measurements are well documented and all that's left now is to break them in and enjoy!. Good Job! (y)
Reactions: 1
It is a Detroit True Track. I've really only noticed it once while driving through a blizzard this past season. Half of the road was packed powder and the other was thawed wet pavement in the sunshine and heating up. I felt it engage fairly hard/grip. I wasn't ready for it the first time and it pulled to one side fairly firmly. I won't go as far as to say a lurch or a jerk, but a firm pull. I got used to it fairly quickly, but had to slow down to deal with it. Overall, it has been a good limited slip Differential. The rear hasn't really done much since I put her in.(thanks for selling me that BTW). It has helped many times out wheeling but have yet to have a level of slippage while regular pavement driving.
I'm still not done with the repair yet. I am having bent ears on axle shaft issues while installing new 760 U-joints. They're being a pain in the arse.
Definately looking forward to getting some more overland trips in this summer. We're looking in to the Pitkin/St Elmo area on the other side of the mountains from Gunnison and Aspen areas to the south east. I believe that JDGreens has done some time over there a few years back. There is also an old toll road/mountain pass just south of Wolf Creek Pass near pagosa springs area we've been thinking about going back to as well. This repair hopefully has a longer life than the last install. This one got about 24,000 miles on it before it failed, whatever it was that pushed it over the edge into the 'not gonna work' category.
I appreciate the help Doc!
Reactions: 1
