1 - 16 of 16 Posts
They said in the vid that it was refridgeration lines under the floor so that is probablly a Hockey arena
I don't think so Nick,you can clearly see it coming from the ground when it is trickling out from the ground.I was thinking the direct spray from the coolent could have been a reason why the tire went flat.
Discussion Starter · #7 ·
still working for me
IDK it seemed that as the tire got increasingly flat the spray slowly decreased.
It's coming from the ground. Watch as the jeep's front tire hits the ground while the rear's are in the air. It starts spraying straight up even before the rear tires touch the ground.
If you watch a little earlier, you can see the rear tire gain too much traction when it hits the cars. Watch the sidewalls on those super-hard tires flex like mad. That could've been related to the air loss.
If ya'll would listen to the video they clearly say that it is the refrigerant underneath then say it is a Hockey Arena
1 - 16 of 16 Posts
