1 - 20 of 28 Posts
I've never liked the winch bumpers that stick the winch out in front of the grille on XJ's.
So I built my own for my XJ
Here's where the winch ended up at
I am only loosing a little bit of approach angle compared to stock with no bumper.
These views from underneath and looking at the backside of the winch, show how tight of a fit the winch is, it's against the fan shroud on the right side and there's just a little clearance to the
Click to enlarge pics
I made alot of brackets. It took forever!!
I tied all the brackets into this universal winch plate.
Discussion Starter #2 (Edited)
Rt. Inner going in Sleeves nut strips
Inside rail Lt. inner brkt In place
Rt Inner Lt. Lower Rt. Lower
Tapped Lt. side done
Then I removed the control box that mounts on top of the winch, I'll have to remote mount it somewhere else
Then I was able to mount the winch on the universal bracket and bolt it in the vehicle.
I am going to have to clearance a little more of the crossmember and hook up a pull rod to the clutch engagement switch, I'll do that after I build the bumper!
Time to start building the front bumper
I started with some 2" x 1/8" square tube, I would usually use thicker material, but I want to keep the weight down. I hope with some strategic side supports, it will be strong enough for the rocks!
I first cut a couple of notches about a foot from center on each side.
Then I beveled the edges and welded them up
Then a test fit to figure out the rest of the angles
The next one is gonna be a 38 degree wedge that I need to cut out
After cutting I welded that one up and the next one is gonna be 47 degrees
Welded that one up and here is how I am finishing off the end
I'm pretty happy with the fit
Did alot of grinding on the welds and gave it a coat of paint.
I'll be adding side supports and other pieces eventually
Couple of months later....I finally got around to mounting the winch control box, beautiful isn't it?
The cables reach to the winch from this position, but i did have to relocate the remote cable recepticle from where it used to mount next to the switch, to the front of the box.
Then I bolted on the fairlead.
I also hooked up a long bolt that I welded on a T handle for the clutch control
Looks like I lose more approach angle from the fairlead than anything else I've done. Oh well when I go synthetic it won't be so bad.
Brilliant work. I like it.
The mounting brackets you made look ALOT like the factory hidden hitch set-up...
I used to love the look of it. and yours looks great. VERY nice work.
dang, thats awesome, oh and where do you park that beast and when are you not around it...??:D
thats got to be one of the cleanest setups i've seen. nice job...:thumbsup:
Discussion Starter #16
Thanks all, it is very much like the factory hidden winch set up from what I understand. Although I doubt the factory parts are still available.
damn thats sexy, i may do someting like that, except my front bumper is gonna be bigger than that, and it will completly hide my winch
Wow! I love this idea. Can you make the bracket drawing available...?:dunno:
Maybe sell them as a kit at a low cost. I'd be very interested. It's like Detours' kit, but simpler.
Nice write-up/bumper. Did anyone besides me notice in the title it says wonch instead f winch.
1 - 20 of 28 Posts
