Looking for a good used set up. Otk or just heavy duty stuff, or info on a one ton kit.
Or one I can put together, a piece here a piece there.
I ran rustys otk on my last jeep but I'm not looking to spend $600 on it all again. And I already have done components, hd track bar mount, pitman arm and such.
Sent from my N9130 using Tapatalk
You probably won't find anyone selling steering setups. It's kinda rare. The most common I see are the crossover setups. People buy this steering setup and get tired of the tie rod roll so they upgrade again and sell off the kit.
If you wanna go new then here are some stock style HD options:
There is zj v-8 tie rod steering mod but it uses the stock draglink.
There is crown's HD steering system, which is basically the same as zj v-8 but a whole lot cheaper. You can find it for $145 to $175. I just received this yesterday and it's going on my TJ.
There's Currie's HD steering, which is a little over $500 but one of the best. I run it on my XJ and it's been flawless for years.
I'm not fluent in the OTK and one ton stuff since I like to keep the stock style steering.
Mine is a Rubicon express extreme duty 5.5 lift. I run 35-12.5-15 I don't see a problem running the stock drag link. I don't heavily wheel the heep. Just use it for farm repairs and occasionally getting to the fishing hole.
I think I'll try out the Currie setup, I've used their products in the past with good result
