I'd appreciate someone giving me a sanity check on this:
I have lifted my 2000 XJ 2" with pucks and shackles and went with R.E. shocks all the way around as well as replaced the worn out leaf springs. I went with O.E. because this will be flat towed behind my motorhome and is its primary purpose. On-road manners are the absolute goal. I've already towed it 2k mi in the last couple weeks and it drives just as straight and comfortable as it did pre-suspension work. -Now that the suspension is good to go, I'm ready for tires. I'm currently looking at M.T. sidebiter II 15 x 8 wheels with 3-5/8-back-spacing & -22 offset. I'd REALLY like to get to a 31" x 10.5 tire but am aware that I might/probably will have articulating problems show up should I do any off-roading, so I'm also looking at the 30" x 9.5 but that makes me worried that I'm going to have too much negative offset with the wheels.
I'm in analysis paralysis.
Given that this will spend 93% of its life on the highway, what are the chances I can get the 31s stuffed in there with a little bit of clearancing of the seams, etc and be worry free? Presently, there is ~19" from the top of the fender flare / tub to the center of the hub with the stock 16" 235's on it.
