1 - 9 of 9 Posts
You have a leak in the vacuum systems that operate the vacuum motors on the HVAC. There can be two causes. The most common is a leak in the vacuum cannister located on the right side behind the front bumper. Looks like an old cartoon bomb, minus the fuse. There is also a vacuum check valve, looks like a disc with hose barbs on both sides. It might be malfunctioning too. Also look for the obvious cracks in the rubber lines
Discussion Starter · #8 ·
Thank you for sending me in the right direction… I will definitely check everything… have a good one 👍🏼
My friend is looking at this Cherokee with the same issue. He hasn't checked where the air is coming from. We'll take a look at it this weekend after we finished installing the brake pads and jeep wheels on the Wrangler.
1 - 9 of 9 Posts
